Question about removal of Auto Leveling Shocks
Old Nov 6, 2017 | 10:00 AM
mcaramb's Avatar
Default Question about removal of Auto Leveling Shocks
Hey folks, the previous owner of my Disco2 SE7 apparently replaced the auto leveling shock air bags with regular springs, which is working fine, but should he have also pulled a connector or fuse to keep the autoleveling alerts, etc from popping up randomly on the dash? I think this is happenning randomly because the two rear height sensor arms are also both broken off and probably swinging randomly, setting off the alerts. Should I simply glue these down into one position? What other things should have happenned besides just replacing the springs? I don't think the pump is engaging at all, which is good, but not sure if he disconnected it or its just not functional.... just wanted to know if pulling a fuse or two or connector is what you're supposed to do after getting rid of the autoleveling system, but wanted to make sure because it seems to be tied somewhat into the ABS and didn't wanna kill that. Thanks for any advice
MIke
Old Nov 6, 2017 | 11:11 AM
mollusc's Avatar
Find someone with a Hawkeye or other programmer device. There's an option to select air or coil suspension which will turn off the air warning systems.
Old Nov 6, 2017 | 12:03 PM
mln01's Avatar
As mollusc said, you'll need to find someone with a diagnostic tool that can change the setting in the SLABS computer from air springs to coils. Other methods can result in alarms and other problems, including phantom electrical drains that can result in a dead battery.
Old Nov 6, 2017 | 12:35 PM
mcaramb's Avatar
Thanks guys, I suspected as much. I just posted to the group asking if anyone was near me with a Hawkeye as no one in town I know has one much less will touch this car
PabloM
Sep 17, 2012 02:45 PM
lrdave
May 2, 2008 08:46 PM
6115connors
Nov 23, 2007 08:17 AM
chadbormann
Aug 1, 2007 05:51 PM
dailyuser
Dec 31, 2005 06:22 PM
