Question on leaks
Old Sep 27, 2009 | 06:13 PM
Scott R's Avatar
Default Question on leaks
New member, have been lurking here a while gathering some great information. I paid a few hundred dollars for an 01' Discovery II that a buddy of mine had left over from a divorce. It runs and drives like a champ, has around 11k on the clock and looks terrific.
Now the bad, and where I need advice... The transmission pan has a cantaloupe sized dent in it, a corresponding dent exists on the passenger side exhaust line. The pan leaks, terribly. I've a new gasket set on order, but should I also replace the pan? I was going to just true up any waves in the edges and seal it back up, but pans appear to be pretty cheap...
Secondly, I have one heck of an oil leak up front. I ran dye marker through and it's the front main. No issues here, will replace it, but what else should I do "while I'm in there?" Hoses? Timing set?
And lastly, both the tail shaft and front output shaft seals are leaking. I was going to just drop the exhaust and possibly the t-case and seal those guys up. Any issues with that approach?
I'm an ex-wrench (15 years ago) but my garage has a 4 post lift, heater and every tool under the sun. I don't cut corners, so if you guys can think of anything else I should do while I have these parts out let me know. I have the latest Rave, it's just not good on real world experience.
Old Sep 27, 2009 | 06:21 PM
I would replace the trans sump.
With only 11,000 miles on it I sure would not waste my time on the timing chain and gears.
You can replace the t-case seals while it is in the truck, but before doing that I would change the fluid and switch to a 84w-140, 90% of the time the leaks will stop once this is done.
Use the same gear lube in both the front and rear diffs too.
Old Sep 27, 2009 | 06:36 PM
Scott R's Avatar
Thanks! I just noticed the fill plug on the front diff is leaking as well, and I'll do this. PO has a receipt from "grease monkey" in the glove box for $300+ dollars, and nothing on that receipt looks correct to me. Wrong fluids, incorrect filling of the transmission etc. I guess you get what you pay for.
Old Sep 27, 2009 | 08:00 PM
Replace those POS plastic fill plugs with brass ones on the diffs.
Old Sep 27, 2009 | 08:09 PM
Scott R's Avatar
Thanks, they're plastic, will order the proper plugs.
Old Sep 27, 2009 | 08:41 PM
Darover's Avatar
Front and rear output seals are straighforward jobs, once you get things out of the way.
Old Sep 27, 2009 | 08:50 PM
Robmcin's Avatar
A few hundred dollars for a Disco two with eleven thousand miles????
That has to be the buy of the decade right there!!
Old Sep 28, 2009 | 08:38 AM
Scott R's Avatar
It's been sitting in the garage of my buddies mountain house, wife got the house, he got the truck. They used it for getting groceries once in a while when the weather was bad. I paid for basically the plate and title transfer, it was a nasty divorce.
Old Sep 28, 2009 | 11:40 AM
See, this is why I rent...nothing to loose. LOL!!!
Old Sep 28, 2009 | 12:41 PM
okdiscoguy's Avatar
except your payment every month.....
