question and opinions needed
Old Nov 28, 2009 | 06:50 PM
01disco2's Avatar
Default question and opinions needed
I just took my truck to the shop a month ago becasue it started overheating. They replaced the thermastat, some coolant hoses, and the serpentine belt. In the last week i have started to hear the "waterfall" noise again in the dash on the passenger side. Its not currently overheating. I'm wondering what i should do. Do i need to take it back in, or just live with it until it does overheat again?
Old Nov 28, 2009 | 07:12 PM
Take it back, you have a leak.
If it was low on coolant when you first took it in they should have looked for a leak before they did anything else.
So far all they have done is take your money.
Old Nov 28, 2009 | 07:55 PM
devildog01's Avatar
Take it back right away.If you wait till it overheats it will be to late.Better safe then a warped head.
Old Nov 28, 2009 | 10:34 PM
AK Rover's Avatar
We may not always have the right answer but we always have opinions.
I agree with the others that you have a leak somewhere in the cooling system. The waterfall sound you hear is an air bubble in the heater core. Until you fix the leak and properly bleed the system you'll continue to have that sound. Take it back to the mechanic and have them find the leak.
Old Nov 29, 2009 | 07:51 AM
hilltoppersx's Avatar
the thermostat and belt were most likely not a bad purchase anyway, should be done regularly, although you could have done them yourself. but like everyone else said go find the coolant leak.
ALAKDisco
Feb 17, 2012 08:38 AM
Snafu / Disco Fries
Oct 15, 2010 07:30 PM
Inniswhe
Jun 17, 2009 09:17 PM
johnkbl
Dec 29, 2008 06:12 PM
Freelander1981
Freelander
Mar 14, 2006 04:27 PM
