Question on prop shaft.
Old 08-11-2012, 08:55 AM
cagusmc's Avatar
Originally Posted by jbkroh
well we just finished getting the propshaft out...rebuild for tomorrow
no gease fittings but everything was still real tight, maybe i'll just put it back...........kidding
Did you have any problems getting the shaft out? I'm thinking of buying a rebuilt prop shaft and doing the work myself, if its not too much of a hassle?
  #22
Old 08-11-2012, 09:50 AM
lr2001silver's Avatar
Banned
Getting the front drive shaft out is pretty easy job its four bolts on the front diff side and four nuts on the transfer case side the bolts on the transfer case side will stay in the flange. The truck will either need to roll or be lifted in the air as the four nuts will be a little difficult to get to without turning the drive shaft 180° but it is possible to do.
  #23
Old 08-11-2012, 10:15 AM
cagusmc's Avatar
Great. I'm going to order a prop shaft on Monday. Thanks again for the help.
  #24
Old 08-11-2012, 10:25 AM
Banned
Your welcome, you ordering from dynamic?
  #25
Old 08-11-2012, 10:40 AM
cagusmc's Avatar
Yes I think so? they seem to have the best prices around? Do you have any experience with their shafts? Are they GTG?
  #26
Old 08-11-2012, 11:32 AM
Banned
Yes i do use it and so does Mr drowsap i "think". It is a great unit ready to go bolt in and go. Also a great price!!!
  #27
Old 08-11-2012, 01:12 PM
jbkroh's Avatar
Default here's to you oh prevaire of disco knowledge
shaft out is a snap.
as i said everything "looked" tight upon removing the iniversals
all of the caps and bearings were still wet with factory grease
and buetiful shiney needles, then it happened removing a cap
there was dust were grease used to be and needles that were all but
pins.
many thanks to all who harp on changing front shaft UJs
now on to that dang center ball
j
ps: can a disco be run on the back axle alone, i need a few more beers
  #28
Old 08-11-2012, 01:21 PM
Banned
Yours can but not all some transfer cases do not have the linkage to do so you have to engage the cdl
javasteve
08-23-2013 02:51 PM
amaxson
06-22-2011 05:27 AM
blcp86
07-24-2009 07:49 AM
aaveryy
05-12-2007 07:51 AM
Quick Reply: Question on prop shaft.
