Prop shaft install question
Old Aug 21, 2013 | 08:50 PM
javasteve's Avatar
Default Prop shaft install question
OK, I am getting my new GBR prop shaft tommorow. When I removed the old one a few days ago to get the last nut off the transfer case I put it in neutral and turned the shaft so I could get the socket on it. when putting it back on should I worry about doing that. Common sense says no, but hey this is a land rover and really common sense is half gone with this truck. The front was unbolted when I did this.
Old Aug 22, 2013 | 08:50 AM
Just do the reverse of what you did when taking it off, no big deal. Make sure you grease the new shaft as well as the rear shaft when installing.
Old Aug 22, 2013 | 08:54 AM
drowssap's Avatar
it is good practice in the future to mark the yolks
Old Aug 22, 2013 | 12:03 PM
antichrist's Avatar
I don't bother, when my eggs are scrambled the markings are lost.
I do mark my yokes when rebuilding.
When replacing a propshaft with a different one, I don't.
Old Aug 23, 2013 | 08:21 AM
javasteve's Avatar
Got it in. Works great. Almost all the front end vibration is gone. Greased the crap out of everything.
Old Aug 23, 2013 | 08:51 AM
re: Greased the crap out of everything
Please repeat every oil change.
Old Aug 23, 2013 | 02:51 PM
javasteve's Avatar
I actually set it up to grease once a month in my phone for the front when winter hits, with all the salt on the road in MN I am going to over do it. Grease is cheap.
Alex_M
Sep 7, 2024 05:21 PM
cagusmc
Aug 11, 2012 01:21 PM
amaxson
Jun 22, 2011 05:27 AM
blcp86
Jul 24, 2009 07:49 AM
aaveryy
May 12, 2007 07:51 AM
