Question whether TDI has same Cr.S. pulley as gas model
Old Sep 2, 2015 | 02:46 PM
Chrisinhouston's Avatar
Default Question whether TDI has same Cr.S. pulley as gas model
Not sure if anyone can help as I know that the TDI engines are not sold in the USA market. I am going to replace my leaking front crank seal in the front cover and will need to remove the main pulley. Land Rover specifies a LST 12-280 which attaches to the front of the pulley and bolts in place so you can loosen the nut. I found one on ebay for the 200-300 TDI engines but am not sure if it is the same size pulley. I would think it is, there is no reason it needs to be different.
Yes, there are some other less safe methods for loosening the big nut but I like to use the tools designed for the job.
Old Sep 2, 2015 | 03:34 PM
Alphamale's Avatar
Hi Chris, RAVE shows part Nē. LRT 12-080 (my copy is the US RAVE) and I know this is a UK ebay listing Land Rover 300Tdi, 200Tdi / Jaguar Crank Locking tool (LRT 12 080) (VS4985) | eBay but it shows the tool you speak of @ $91.80. I even adapted one to fit my LR3 V8.
dirkha
Feb 10, 2021 06:44 AM
HKROVER
Aug 19, 2007 06:00 AM
Dylan
Oct 23, 2006 04:36 AM
to666ny
Freelander
Nov 7, 2005 11:49 AM
