Questions about DIY engine removal
Old 06-16-2018, 01:10 PM
TRIARII's Avatar
When l'm removing an engine or entire unit...usually start by disconnecting the battery and then head underneath.
Get the cross member(s) out, y-pipe/muffler next, cut trans mounts or unbolt, unbolt motor mounts, remove driveshafts, remove parking brake cable, cut all electrical connections, etc.
Once all of that stuff is handled...l start draining fluids (anti-freeze, oil, trans and transfercase). See folks all the time...start draining fluids first...and then they get dripped on the whole time they are removing stuff underneath.
While fluids are draining...l start unbolting accessories (ps pump-bracket, a/c compressor, alternator, etc). I like to remove the exhaust manifolds, yes, takes longer...but gives you more wiggle room. Then take the Sawzall and cut anything and everything that needs to be out of the way to remove.
You'll probably need an engine hoist and floor jack to remove entire unit...relocating lift chains and jack under trans as it moves forward in the chassis.
Brian.
how do I disconnect the e-brake cable from the drum?
Old 06-16-2018, 04:11 PM
The Deputy's Avatar
Received 1,275 Likes on 896 Posts
You can either remove it from inside, by pulling window switch plate and gaining access through there to disconnect, disconnect and pull down through floor...or remove driveshaft and then parking brake drum and gain access through there, once drum is off...it's kind of self explanatory.
Brian.
cableguy1979
08-21-2016 09:15 AM
abran
08-26-2015 03:13 PM
walkingzach
07-30-2014 08:54 AM
Discolife
06-13-2012 05:14 PM
Bryan H
07-07-2010 08:29 PM
Quick Reply: Questions about DIY engine removal
