engine removal
Old Aug 21, 2015 | 08:50 PM
abran's Avatar
Default engine removal
Im going to try and remove the engine on my LR3 this weekend.
Anybody have any tips? I can't seems to find an access hole for the torque converter bolts, anybody know where that is?
Thanks.
Old Aug 22, 2015 | 08:50 AM
unseenone's Avatar
Engine Removal Engine (12.41.01.99)
Also-
Body Off
DISCO3.CO.UK - View topic - How To - Body Removal
Old Aug 22, 2015 | 10:28 AM
abran's Avatar
So what's the tool for?
I saw a video about taking the body off,is that the only way to remove the engine?
Old Aug 22, 2015 | 01:23 PM
thorgal's Avatar
There was one guy , on this forum, that successfully removed a 4.4 engine on LR3 without taking a body off. I think , i have read about that last year .He took a radiator off and was able to lift the engine out without taking a majority of accessories .He said , it was tight, but doable. That all I remember, can's seem to find a link to his post though...
Old Aug 22, 2015 | 03:30 PM
abran's Avatar
Well, I started. Removed all the under plates, Sway bar, front air shocks, bumper, fender flares, fender well trim, and fenders.
Then I started on the radiator and fan clutch. Fan clutch was kicking my butt, until I realized it was a left handed thread, opposite of the D2s I am used to. disconnected all the cooling lines and removed coolant tank reservoir.
Things look tight, I am not too thrilled about it, but I am going to have lunch and hit it again.
I'll keep updating as I progress.
Old Aug 22, 2015 | 09:28 PM
abran's Avatar
Got the AC system cleared, removed the radiator and AC condenser.
Removed the T case support/sub-frame, both Cat pipes, and the front driveshaft.
Got the 3 Torque Converter bolts un done and then miraculously got all the bell housing bolts off... Not easy.
If all goes well tomorrow I just need to unbolt the engine mounts, disconnect fuel lines, and all the electrical. After that I just need to figure out where to strap it for the Cherry Picker.
Overall feeling good. Should have it out tomorrow.
Old Aug 23, 2015 | 10:39 PM
abran's Avatar
Trans and t case out, engine is disconnected, but the engine mount tab keep getting caught in the steering shaft. I gave up for the day.
Going to try and remove steering shaft tomorrow.
Old Aug 24, 2015 | 05:31 AM
AtlantaViking's Avatar
I'm really hoping you are taking some pics as you go. You've got a great detailed thread going!
Old Aug 24, 2015 | 11:45 AM
abran's Avatar
Pics...? I knew I forgot something.
I will try and take some pics that will help the next guy. I will also post up bolt counts for the bell housing and the T case to Trans union.
Old Aug 25, 2015 | 01:13 PM
abran's Avatar
Motor is out. The steering rod was the only thing holding it from coming out.
