questions about front lamp guards
I've got 'em, but no pics.
They're ABS and will probably hold up to moderate abuse short of a direct hit with a hammer or large shrub.
Install was pretty easy. Drill 4 hours using the included template and screw it together.
Tis' a pain in the rear when you have to change bulbs, though.
You can probably find them cheaper elsewhere.
I have them lamp guards on mine, plenty of pics on my webpage......
As far as "what" they fit, your are "half" correct,
The lamp guard is identical for 01 or 03 models, BUT the mounting is not, on a 01 they screw directly to the grilles outer edge / border, on an 03 the grille has no outer edge,the slats go full width so you need the "in fill" which sits in the grille slats and the lamp guard screws to that, this is why the 2 kits have diff part numbers ref diff model years
wisconsinoverlander
09-20-2012 01:07 PM
DiscoRover007
08-26-2012 10:48 AM
DiscoBenjamin
11-23-2010 08:22 AM
