questions about front lamp guards
Old Dec 10, 2009 | 03:43 PM
03discoman's Avatar
Default questions about front lamp guards
anyone have these lamp guards... i want pics
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
Old Dec 10, 2009 | 04:32 PM
meltdowndave's Avatar
I've got 'em, but no pics.
They're ABS and will probably hold up to moderate abuse short of a direct hit with a hammer or large shrub.
Install was pretty easy. Drill 4 hours using the included template and screw it together.
Tis' a pain in the rear when you have to change bulbs, though.
You can probably find them cheaper elsewhere.
Old Dec 10, 2009 | 04:58 PM
Disco C's Avatar
those are the wrong ones for an 03.
Old Dec 10, 2009 | 05:36 PM
03discoman's Avatar
they will fit on a 2003...
i have seen them... there is no difference in the dimension of the headlamp, fender or grill... either way i can make them work or return them
Old Dec 11, 2009 | 02:29 AM
Urban Panzer's Avatar
I have them lamp guards on mine, plenty of pics on my webpage......
As far as "what" they fit, your are "half" correct,
The lamp guard is identical for 01 or 03 models, BUT the mounting is not, on a 01 they screw directly to the grilles outer edge / border, on an 03 the grille has no outer edge,the slats go full width so you need the "in fill" which sits in the grille slats and the lamp guard screws to that, this is why the 2 kits have diff part numbers ref diff model years
Old Dec 11, 2009 | 01:54 PM
Disco C's Avatar
he can make them work. just thought it might be easier to get the correct part. no good deed goes unpunished.
Peter Van Slyke
Sep 3, 2013 07:39 AM
wisconsinoverlander
Sep 20, 2012 01:07 PM
DiscoRover007
Aug 26, 2012 10:48 AM
DiscoBenjamin
Nov 23, 2010 08:22 AM
sloppyjoe
Sep 19, 2010 12:38 AM
