questions about installing new Terra Firma shocks-2" lift
Old Aug 29, 2013 | 09:41 AM
joyntanovich's Avatar
Default questions about installing new Terra Firma shocks-2" lift
Hello everyone,
It's been a long time since I've worked on a Disco II suspension. My rig has 2" spacers with stock springs.
The shocks that the previous owner put on Rancho 9000's are destroyed, rig is literally rebounding multiple times over any bump/rounding corners! = bouncy house.
I got new Terra Firma's for it for $35 apiece (long story, but Rover shop had a guy pay for half, then rolled his Rover), so I got a great price!
QUESTION: I've watched the Rover's North 2" lift kit install video (
), BUT, I am wondering:
Should i remove the stock shock towers just to replace front shocks? (sorry if this is a stupid question).
Trying to get the replacement done quickly!
Also, in the video, they remove the front yoke and upper sway bar mounts: are these both neccessary for just placing shocks?
Thanks a ton in advance.-CJ
Old Aug 29, 2013 | 09:46 AM
You can install the shocks with the shock tower off or on, I prefer off.
As for the p;d coils and spacers. you should never run spacers on your ols warn out springs, your top heavy vehicle becomes more unstable when wheeling.
Old Aug 29, 2013 | 09:47 AM
ZGPhoto's Avatar
We only removed the shock towers in that video to replace them with the competition shock towers. You definitely don't need to remove them, makes it a lot quicker!
Old Aug 29, 2013 | 10:00 AM
acamato's Avatar
When I did my springs and shocks. I did remove the towers, they are only held in with 4 bolts. If you don't remove the shock towers, you may not be enough room to get the shock bolt out.
I have ACE and did not have to disconnect the endlink or actuator.
Lucky8 has a video on it also.
Another thread on install - https://landroverforums.com/forum/di...-report-44338/
Wreckdiver also has a post in his blog about his install - The Disco: Suspension – Part One | Montana Overland
Old Aug 29, 2013 | 10:38 AM
dusty1's Avatar
the bolt marriage to the isolator, atop the spring (the 4 bolts) has a tendency to rust and weaken. be prepared to snap one if you remove and re-install the turret. not a definite, but i have snapped a few.
Old Aug 31, 2013 | 09:27 PM
Default re: terra lift install-popping sound
I got the front shock towers and shocks, out, replaced, etc with no issues.
The rear shocks were another story. removal was easy, even though the rear shocks were toast, rusty, old, etc.
the new Terra shocks (RNA 128) had wider shock "heads/ends" than the previous set. required widening the mounting locations top and bottom.
We got that done.
Now, when ever i go over a decent size bump in the road, there's a popping sound from left rear.
I checked bolts; they are tight.
Since the lift is a 2 inch spacer under the spring, could it have something to do with that?
trying to figure out what would make it pop!
Thx CJ
Old Aug 31, 2013 | 09:30 PM
ZGPhoto's Avatar
If they are not located correctly in the upper spring seat you can have that problem. Check to make sure your springs are fully seated.
Old Aug 31, 2013 | 09:55 PM
Default re: popping sound
Thanks Zach, I will check that and reply back. BTW, the Terra Firma shocks ride a million times better than the Rancho 9000s the previous owner had installed.
CJ
Old Aug 31, 2013 | 10:01 PM
ZGPhoto's Avatar
Yeah I hear you, I bought a vehicle with tired OMEs and they road terrible.
RoverPete
Jul 29, 2015 05:45 AM
acg
May 11, 2015 10:20 PM
caymandrew
May 9, 2015 10:05 PM
Rov3r
Sep 17, 2014 11:59 AM
tweakrover
Feb 27, 2011 03:37 PM
