questions for those with a 3 inch lift
![Wink](https://landroverforums.com/forum/images/icons/icon12.gif)
I've been talking with rovertym about options to lift my disco. They recommend -
3 inch Springs
Ome sport shocks
Brake lines
ABS extensions
Adjustable panhard bar
Rear Watts linkage
Caster corrected radius arms
Remove sway bars or quick disconnects
Am I missing anything?
3 inch Springs
Ome sport shocks
Brake lines
ABS extensions
Rear Watts linkage
3 inch Springs
Ome sport shocks
Brake lines
ABS extensions
Rear Watts linkage
3 inch Springs
Ome sport shocks
Brake lines
ABS extensions
Rear Watts linkage
x2 Old Man EMU. They sell a great 1.75" suspension kit specifically designed for the Disco II like NT suggested. Coils, shocks and steering stabilizer. The kit is $700+- and you can install it yourself.
![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
Here,
http://www.rocky-road.com/discosus.html
________
****TBE
Here,
________
****TBE
I haven't ruled out the two inch, but I am seriously considering the 3 so I'd like to hear from those with it.
A 3" lift with the parts I listed should be more capable than a standard 2". As it stands now, I'm bottoming out the front and rear bumpers on the trail, and I'd like more clearance and more articulation.
RTE is recommending what is needed for extreme articulation. If you're not going to use your truck for extreme stuff you can save a lot of money by eliminating the Watts links and the front radius arms from the setup. I ran the HD OME and had plenty of flex without all that stuff.
The watts linkage is for the rear axle while the radius arms are on the front axle. Just changing one doesn't effect the need for the other.
