Quick ? on CPS
Old Apr 5, 2012 | 08:14 PM
MuleyJ's Avatar
Default Quick ? on CPS
I read through numerous threads about the CPS sensor prior to purchasing my Disco 2 and had planned on keeping a spare in the truck but had not done so yet. I have already ordered 2 bosh sensors so I will have one as a spare, but I wanted to confirm the symptoms before I get into this too far. Drove the Disco the other day for about an hour and a half and shut the vehicle off in the driveway. About ten minutes later it would not restart, just crank like no spark. Came back a couple hours later and it starts just fine, but I leave it idling in the driveway and it dies about 20 minutes later. Next day it starts fine, I get brave and take it to town without issue. Today it will crank over but not start. I tested for spark and there is none to be found, I can hear the fuel pump kick in when the key is turned on. From the threads I have read this sounds to me to be a classic CPS issue, does it sound like I am on the right track or is there somethig else I should be looking into? Thanks!
Old Apr 5, 2012 | 08:55 PM
94svt50's Avatar
Sounds like a bad CPS to me. Where did you buy your bosch brand sensors from?
Old Apr 5, 2012 | 08:56 PM
DonRW2007's Avatar
Default Sounds like a likely culprit
I defer to the more experienced members, but CPS seems a likely cause. It's a cheap issue to address, especially if you have ordered a couple of spares. You will definitely get a barrage of people telling you to "read the codes" before proceeding...
These symptoms are exactly as I experienced about 9 months ago. $75 and problem solved.
Old Apr 5, 2012 | 09:38 PM
MuleyJ's Avatar
I forgot to say I have a scanguage and there are no codes. Thanks guys.
Old Apr 6, 2012 | 08:05 AM
CKP failure often produces no code in certain conditions. See attached pages. When replacing every bolt and spacer must return to same position. The sensor is actually a pickup coil wound around that point that is spaced exactly a certain distance from the slotted disc, and creates a pulse as the disk flies by. Once wire insulation of the coil begins to fail and short out or go open, the pulses are not reliable, ECU stops sending commands for spark.
Attached Thumbnails Quick ? on CPS-d1-reluctor-ring-oil-pan.jpg   Quick ? on CPS-ckp-sensor-internal.jpg
File Type: pdf
Old Apr 9, 2012 | 09:41 PM
MuleyJ's Avatar
Voila! Parts arrived quickly and the install was pretty easy. Runs very well and starts every time hot or cold. Thanks to all.
wiscodread
Dec 17, 2023 11:06 AM
LundRover
Jul 23, 2011 10:32 AM
HemiCrew
Apr 21, 2011 04:26 PM
nickm347
Feb 9, 2011 01:48 PM
possibly owner
Sep 8, 2009 10:30 PM
