Can you bench test a CPS
Old Sep 8, 2009 | 09:10 AM
possibly owner's Avatar
Question Can you bench test a CPS
Still trying to solve my no spark issue. Can you bench test a CPS. I would really like to figure it out instead of parts replacing.
I do not have any spark.
I was told on here that it is not normal that both coil packs go bad, anything else besides CPS a suspect?
Old Sep 8, 2009 | 09:39 AM
98roverguy's Avatar
If you do a google search there's a lot of info on it. You'll likely need a multimeter as well.
Old Sep 8, 2009 | 11:53 AM
I read your other thread...
I do not know if you can bench test a crank sensor or not.
They are fairly cheap and are a VERY common thing to go bad on a DII.
I would replace it, that controls spark and the fuel pump.
That is what tell the plugs when to fire, and no signal from the crank sensor and the fuel pump assumes that the engine is not running so it shuts down the fuel pump.
The coils on a DII can go bad, but not that common.
Start with the $65 crank sensor.
Old Sep 8, 2009 | 08:21 PM
thanks guys, spike the google thing is so obvious i missed it. It makes sense, I don't think I heard the fuel pump. I just hate spending money without being sure.
Old Sep 8, 2009 | 08:27 PM
Hey it happens to the best of us, let us know when you get it figured out.
Old Sep 8, 2009 | 09:18 PM
With a decent scanner you can check pretty much any sensor in live time or snap shot frames.
Old Sep 8, 2009 | 10:30 PM
handsome rob's Avatar
Thanks Mike for chiming in, I was not sure if you could bench test it or not.
I think though that it will cost just as much to get a good multimeter to do the test as it woukd to just buy a new CPS. Heck find another LR buddy and ask if you can test his on your rig, just be careful pulling it out not to screw it up.
Soccer Dad
Sep 16, 2014 09:43 AM
Aaron Sandland
Mar 27, 2013 07:41 PM
A5scott
Jul 29, 2012 11:19 AM
landyjd
Defender
May 21, 2011 11:34 AM
sheelhorse
Jun 25, 2009 10:39 PM
