Quick fan question - 02 or 04 style?
So, in digging into my oil pump project I managed to crack a blade on my already tired 04 fan / clutch assembly. before ordering a new one I did my research and know the earlier 02 style will fit and it is cheaper. Plus I like the two part design. My question is if it works the same for 4.6? The 04 fan has evelen blades vs nine on the 02 style. Not sure if LR improved the fan for the larger engine or decided to cut cost and use a all-in-one style fan that they could also charge more $$ for in repairs.
Agreed with @Best4x4 om the two piece setup.
On my last D2 I was really happy with the heavy duty Hayden fan clutch and the doorman fan. The hardware to attach the two was more difficult to source than it should have been though.
I would avoid the “severe duty” fan clutch. It’s overkill and makes it really hard to hear the motor if you ever need to diagnose a running issue. The heavy duty was perfect for me.
