Quick SVS repair question
Old Jan 27, 2013 | 02:49 PM
MC04DII's Avatar
Default Quick SVS repair question
I was doing the shuttle SVS repair and had to abandon because I rounded off the center 4mm hex screw enough to where I can't get it off without at least undoing the brake lines and flipping it over for better access. If I undo the brake lines, will all I need to do after is a 4 wheel brake bleed, or is it a more involved bleeding process? Also, thinking of going to the local pull a part where they have an 02 disco and taking that SVS plate for a spare just in case something breaks. Thanks.
Old Jan 27, 2013 | 02:57 PM
jafir's Avatar
Best practice is to bleed it with a computer, after bleeding it by hand. You can get by bleeding it by hand and then making the modulator do some work, bleeding it again, but there is no assurance that you'll get all four circuits to work so there still might be a little air somewhere.
Both times I've done this repair, I removed the modulator. It's too much work trying to do it in place.
Old Jan 27, 2013 | 03:11 PM
MC04DII's Avatar
Ok, so this computer bleed needs to to be done by an indy or dealer I assume? Is this an expensive bleed or is it what they normally charge for a bleed? Strapped for cash student, so trying to schedule around big repairs. Also, my modulator makes a faint hum type sound that I can hear when I put my ear up to it. It does this even while the car is off and has been sitting for awhile. Is this normal? Thanks
Old Jan 27, 2013 | 03:23 PM
jafir's Avatar
Yes or someone with a hawkeye or nanocom or similar. I think you'll be fine waiting though. The way I did it manually, before the hawkeye software support bleeding, was to bleed at the lines coming into the modulator, then bleed at the lines coming out, and finally bleed at each wheel.
Old Jan 28, 2013 | 11:53 AM
SuperSport's Avatar
I just noticed the other day that mine also makes noise, tick/hum, with key out. Someone on these forums said they make noise for about 10 minutes after key is out, then it shuts off. I have not timed mine yet to see, but I can confirm the noise with key out.
Old Jan 28, 2013 | 12:00 PM
drowssap's Avatar
as Jafir said you can bleed it manually just take one section at a time and bleed it at every connection.
A hawkeye or other tool would make it a lot more enjoyable, but is not nessasary.
old sckool style "pump it hold it down. pump it up hold it down"
Old Feb 1, 2013 | 01:39 PM
MC04DII's Avatar
Well did the repair, and a manual bleed. Took it out and tested the TC and HDC. Works like a charm and no lights! Great repair!
baburhan
Dec 30, 2011 06:50 AM
coors
Nov 14, 2011 10:20 PM
icyhot201
Aug 16, 2010 07:24 PM
yuenie
Dec 17, 2009 04:29 PM
endneu913
Nov 3, 2007 03:46 PM
