R380 Oil Pressure Switch
Old Apr 18, 2019 | 04:22 AM
markdeg's Avatar
Default R380 Oil Pressure Switch
Have read somewhere that you can use the existing housing for the temperature sensor fitted on V8 models to fit an oil pressure switch, which operates a light in case oil pressure becomes too low (catastrophic oil leak?) Sounds like something which is "too easy" not to try and do, anyone has done it and can point me towards the right type of sensor/switch required?
Thanks!
Mark
Old Apr 18, 2019 | 06:39 AM
mollusc's Avatar
how would "a light in case oil pressure becomes too low" be any different from the existing light that comes on when the oil pressure is too low?
Old Apr 18, 2019 | 06:57 AM
markdeg's Avatar
im talking about adding an oil pressure switch to the R380 manual gearbox
Old Apr 18, 2019 | 08:23 AM
mollusc's Avatar
sorry -- missed that bit. would a pressure sensor have to be calibrated for transmission oil rather than engine oil?
Old Apr 18, 2019 | 08:36 AM
ZGPhoto's Avatar
Serious question, what would a gearbox run for oil pressure? Do you have that info?
Old Apr 18, 2019 | 11:07 AM
Red5's Avatar
The R380 does have a pump just below the rear output. I don't know where you would actually tap into the case to measure the pressure though.
Old Apr 18, 2019 | 11:37 AM
mollusc's Avatar
from the rave (p.37-7)"
"Lubrication is by an oil pump located in the extension housing and driven by the layshaft with additional lubrication being provided by splash. The pump directs oil via a filter and internal drillings in the output shaft to lubricate the components. On non UK and non European models, provision for oil cooling is by means of a thermostat housed in a cover bolted to the side of the extension housing. The cover incorporates tappings for connections to an oil cooler. On UK and European models, the thermostat and cover are replaced by an oil by-pass block."
so it seems like you should be able to tap into the lines running to the oil cooler, or if you have a uk/euro truck, by getting the thermostat cover from a foreign truck and using the oil cooler port for a pressure switch. i don't know whether the thermostat would allow full pressure into the oil cooler lines unless the temperature was high enough.
Old Apr 19, 2019 | 08:58 AM
markdeg's Avatar
Hmm, thanks for the replies, seems like it isnt as straight forward as i hoped for but probably doable. My gearbox does not have the oil cooler so i would need the manifold. My main concern is detecting severe oil leaks before it is too late. I know some people who destroyed their boxes in that way
Old Apr 22, 2019 | 05:33 AM
markdeg's Avatar
it seems there exist aftermarket oil cooler kits that do not use a thermostat, but a simpler adapter block. will try to fetch something like that.
escott16
Jun 13, 2018 04:14 PM
CandiMan
Engine & Internal
Jun 11, 2014 09:18 AM
rewi9d
Apr 12, 2012 06:12 PM
MrFlea1
Jan 30, 2012 08:07 AM
ArmyKen
Apr 10, 2011 09:16 PM
