Sponsored by: CARiD
Intermittent oil light
Old Apr 10, 2011 | 08:31 AM
ArmyKen's Avatar
4wd High
Default Intermittent oil light
My oil light is coming on intermittently. There is no knocking, over-heating, leaks, or loss of power. I noticed it starting shortly after relacing my spark plugs and am guessing that i disturbed the oil pressure sensor or wiring during the process. Any info on where the sensor is located? Any other ideas?
Although the oil level was fine, I changed the oil and filter yesterday. (It was due soon anyhow)
Old Apr 10, 2011 | 09:09 AM
d2luvr's Avatar
I believe the oil pressure sensor is on the front cover low. Time for real oil pressure numbers. You don't want to find out you have a bad block the hard way.
Old Apr 10, 2011 | 09:12 AM
d2luvr's Avatar
You might want to search for oil pump VIN range, as it will walk you through the testing process and let you know how to hook up the pressure gauge and some of the problems with low oil pressure.
Old Apr 10, 2011 | 09:16 PM
Above the oil filter on the block is the oil switch.
ndinsmore
Jan 27, 2016 09:47 AM
Michael Haas
Sep 11, 2013 01:54 PM
oljohnboy
Aug 3, 2012 09:40 PM
tacker
Jul 10, 2010 09:36 PM
johnboyairey
Oct 15, 2008 06:16 PM
