Radiator Fan temp? - Cooling
#21
#22
Check the math on that computer by restarting the trip odometer when you fill up the tank. When you refuel, fill it back to the top - you now have gallons and miles to get an actual mpg calculation.
#23
Right, Not possible. The OBDII port has no way to measure actual MPG, It is not a function of the ECU, it is just an estimate based on user input.
As mentioned the only way to really know is the old fashioned way... And use a GPS for you actual miles rather than your odometer... Could be off by as much as 5%.
Micmac
08-22-2020 02:54 PM
