Radiator Hose T
Old Jan 20, 2013 | 11:46 PM
prroverguy's Avatar
Question Radiator Hose T
So, I open the hood and sure enough, my 04 Discovery was leaking antifreeze through the plastic T. Took the hose clamps and hoses off to give her a check, and the plastic T had been crushed by the clamps and I could see most of the plastic was dry-rotted where she busted. I'd hate to buy plastic components as I can foresee running into similar problems later on, and can get my hands on stainless steel T tubing, and have the experience to build something more reliable... Can anyone give any opinions?
Old Jan 21, 2013 | 12:24 AM
People have remade this part with plumbing parts as well. IMHO the fitting of a bleeder that can take a piece of clear plastic hose into a bucket would be a plus, as it would allow you to bleed and see a string of bubbles coming out, instead of cutting off the bleed process at the first burp.
Old Jan 21, 2013 | 12:25 AM
KindaGuitarded's Avatar
That might be one of those million dollar engineering ideas....or at least get most of us to buy it.
Old Jan 21, 2013 | 12:48 AM
prroverguy's Avatar
Thank you!
Old Jan 21, 2013 | 06:42 AM
mln01's Avatar
Why not just tap the hole instead of welding on a nut? Drill a 3/8" hole, use a 3/8" tap, and put an O-ring on a short 3/8" cap screw. Maybe I'll try this.
Old Jan 21, 2013 | 07:12 AM
jeffh's Avatar
If you build it.. they will come.
I have tried to find someone to build one out of brass for the last 2 years. None of the machine shops I know want to put the time in. Brass, Stainless Steel, Black Iron. Really I do not care, make it, and make it quality and, well... as I said up top, they will come.
Old Jan 21, 2013 | 09:16 AM
Sounds like a trip to the plumbing distributor. But counter sales to the general public vary by distributor, some have high minimums.
Old Jan 21, 2013 | 11:35 AM
prroverguy's Avatar
Well, its not 1 1/2" tubing, so I had to order 1". Will post pics when done!
Old Jan 21, 2013 | 12:29 PM
04duxlr's Avatar
The hoses are 1 1/4" or 32 mm. Make sure you get the correct size.
You can tap the body for the bleeder without any problems. There isn't much pressure in a cooling system, so the tee won't fail. Someone just posted a picture of teir setup. They had fitted a little valve for the bleeder but it was too tall to fit under the hood. I think the machine srew and o-ring idea is the best approach
Old Jan 21, 2013 | 01:56 PM
blamo's Avatar
What would people pay ? might be worth braking out the tig welder peanut grinder & chop saw.
