Radiator Out, Questions About Screws
Old May 8, 2021 | 02:47 AM
WildPackofFamilyDogs's Avatar
Default Radiator Out, Questions About Screws
Hello everyone,
I took the radiator out today of my 04 D2 SE and i have some questions about the screws used in the radiator mounts.
i looked up the part number in my parts list and was unable to find it.
Are all the Phillips head screws the same? The screws I am referring to are the fan shroud screws, the two bracket screws, the two middle mount screws.
as well, is there a bolt or a different screw I could use on the top? If not I think I’ll use two or three washers with the fan shroud screws
Thanks
Old May 8, 2021 | 11:07 AM
Dave03S's Avatar
The screws directly above the tanks should be shorter. They are not all the same. But good work being proactive about not puncturing your tank.
Old May 8, 2021 | 07:04 PM
Discorama's Avatar
For the brackets I got hex screws called "license plate screws" from the local hardware store. They are much easier to install/remove than the original phillips.
Old May 10, 2021 | 10:51 AM
dswilly's Avatar
As Dave03S said. This is potentially a huge fail if the screws get mixed up. When I did my radiator change I measured the distance (about 5/8" I think) to the tank and made sure the screws were considerably shorter. I only knew about this by reading before I did the swap. If not I could have easily ran the wrong screw in and ruined a new radiator. The screws only need to thread in a little to do the job. Recently I bought shorter replacements and ground the ends flat to be safe.
Old May 10, 2021 | 11:09 AM
redwhitekat's Avatar
those screws have caused lots of leaks, they must be shorter, i but mine after my rad leaked
CollieRover
Oct 11, 2016 11:47 AM
04duxlr
Jan 12, 2015 07:01 PM
buick215
Dec 14, 2014 04:10 PM
saallencam
Jun 16, 2012 01:05 PM
photocrimes
May 30, 2011 12:45 PM
