Radiator test (video)
Old May 8, 2018 | 09:13 AM
LR03NJ's Avatar
Default Radiator test (video)
Hi Guys,
Just made a video to test radiator efficiency. I had issues since the weather got warmer. Now its all good.
Cheers
Old May 8, 2018 | 10:15 AM
Saturnine's Avatar
Nice.
so just garden hose cleared up any blockage you had?
Old May 8, 2018 | 10:44 AM
LR03NJ's Avatar
Originally Posted by Saturnine
Nice.
the 1st owner said that 3 shops diagnosed head gasket replacement. Sold truck instead last fall and I used it entire winter with no issues until weather got warmer. It seems they used some stopleak or something. I see silvery chunck of dust on pipes.
About your question, i did not try coz I got a used working radiator. Someone suggested get CLR and fill radiator and keep clr overnight and flush. It might work but I dont use plain water that builds up crystal deposits. Not sure if clr works on hardened coolant or dexcool.
Old May 8, 2018 | 11:08 AM
Best4x4's Avatar
The CLR treatment is a last ditch effort to try and remove any water based deposits. Alot of people are cheap & just top off with tap water. Eventually it gets stuff like calcium/iron deposits. CLR can remove some of that junk, on a cheap budget vs a new radiator. I myself just replace the darn thing for 50-75.00.
I did the CLR treatment on my RRC & D1 because those radiators aren’t 50-75.00 and it did break up a lot of crap inside those radiators.
Old May 9, 2018 | 08:14 AM
OffroadFrance's Avatar
X1 ................ always use 50/50 OAT and RO filtered water, generally ordinary tap water is full of calcium and iron deposits which harden on the matrix and block the rad.
acg
Dec 30, 2014 08:33 PM
Fivespddisco
Sights N Sounds
Mar 11, 2013 08:44 AM
Fivespddisco
Feb 13, 2013 02:51 PM
IB Adrian
Off Topic
Jan 2, 2010 02:23 AM
tom
Nov 12, 2006 01:14 AM
