Radio Code
I was going to pull my radio out to check the antenna lead as I suddenly only get the stongest FM stations in my area, the rest (which used to be ok) are now static ridden.
I have all sorts of original stuff (the manual, window sticker, sales receipts, etc) but I could not find the code anywhere.
What is this bit about having an hour or so with an 04? Is there something different? I have an 04 and if I have a time allotment I will be sure to reconnect power within that timeframe. Since I have a local Rover Indy shop, I have no use for a dealer and prefer not to dig out the title and waste time calling and faxing if I do not need to.
Thanks for any insight!
Thanks! I will give it a shot. I did not know there was an aerial amp back there. Now that I am thinking about this, the problem started after I drove 6 hrs to NYC and back through a monsoon the whole time. I had a little water on my rubber mat in the rear but could not pinpoint any specific leak. The sunroof and upper safari windows were all dry inside, so I think it was coming in through the rear hatch seal somewhere as the inside of the hatch had some water drops on it.
I bet water got back in that area and blew the fuse - at least I hope as that would be an easy fix. Thanks again for the tip and picture! I'll let you know what happens!
Well I went to the passenger fuse box first and the radio fuses were all fine. As I went to the back to start taking apart the paneling to get to the antenna amp, I noticed that the little black connector to the window from the amp was broken on the passenger side. The driver side is fine, but the passenger side is just hanging there by the wire with a faint edge resting on the window. It must have been bumped when packing or unpacking the Disco on the trip to NYC.
So now I need to know the best way to fix this? Is there a specific adhesive that allows the electrical signal to pass through better than another? I do not know what the actual black material is made of that bonds the connector to the window, but I am guessing it is not something I am going to find or be able to use as it looks like it is baked on in a factory.
Any insight on the best fix would be great! I can take a picture if my description is not clear. Thank you!
