Radio/Wipers Do Not Work
Old Feb 5, 2010 | 02:51 AM
MarvelVT's Avatar
Default Radio/Wipers Do Not Work
I just picked up a 2001 DII and I'm having a couple issues. The radio doesn't work. It's not asking for a radio code, it doesn't even turn on. I got another radio and it will does the same thing. As far as I can get either one to go is just illumination as far as the buttons but not turning on. My front and rear wipers are also not responding. I put in a known working switch and it still does nothing.
I've checked all fuses and traced as many wires as I can and I can't find anything wrong with them. Is there anything I should pay attention to? Someone has mentioned possibly the body control module. Is this a possibility and are they VIN specific?
Thanks for any help
Old Feb 5, 2010 | 06:24 AM
Rovin4life's Avatar
start diagnosing with a test light and a volt meter.
that is what I would do.
Old Feb 5, 2010 | 09:43 AM
okdiscoguy's Avatar
Go back through and check all of your fuses again. Put a test light on both sides of the fuse, don't just ohm them out.
Old Feb 6, 2010 | 03:13 AM
Rover Chris's Avatar
if you are going to test the fuses with a test light make sure the truck is on when you test
Old Feb 6, 2010 | 07:06 AM
AK Rover's Avatar
Verify all your grounds are clean and tight also. Bad grounds have caused lots of problems.
Street Wolf
Oct 10, 2023 08:11 PM
Rouges
Oct 30, 2012 02:22 PM
funatic
Jan 31, 2012 03:28 PM
Meek
Mar 7, 2007 05:46 AM
tomegun
Apr 1, 2006 10:26 AM
