Radio works, but no sound.
Old Dec 25, 2024 | 03:33 PM
evil_goat's Avatar
Question Radio works, but no sound.
The radio turns on fine, and the volume **** works to change settings on it. However, there is no sound coming from the speakers. All of the fuses are fine. What could be the problem? I have read on forums that replacing the amp or head unit solved it, but how would I know which to replace? Are there ways to repair the units instead? I have had success repairing dead electronics by heat gunning them, so maybe I will try that.
Old Dec 25, 2024 | 09:23 PM
disco96sd's Avatar
make sure the sound control around display is also up
Old Dec 29, 2024 | 01:10 PM
Externet's Avatar
Sound comes from speakers fed by an amplifier under driver seat fed by the radio.
Antenna ---> radio ---> amplifier ---> speakers --->
If none of the speakers sound, check the fuses for that amplifier being powered or the wiring from the radio to the amplifier. Select AM and the steering wheel volume control just in case the volume control on the radio died.
Old Jan 26, 2025 | 02:50 AM
evil_goat's Avatar
I seem to have the same problem as this post, but there was never a resolution. https://landroverforums.com/forum/di...peakers-81562/
My "system enable" pin only outputs 1.16 volts instead of the 12 that it is supposed to when the radio is on. Does anyone know what is causing this? If I jump it with the pin next to it, so that 12 volts is sent to the amp to signal power on, music plays through the speakers like normal. Can I just leave it permanently jumped? There is no voltage when the car is off, so it wont drain the battery.
Old Jan 27, 2025 | 12:01 PM
Externet's Avatar
Hi.
That pin 5 "system enable" appears to turn on the amplifier. Pins 4 (always) and 7 (acc key) are the ones powering +12V to the 'head' unit. If when feeding +12V to pin 5 it all works normal, I see nothing that can go bad by jumping pin 5 to pin 7 as you say. Someday we will somehow obtain a schematic; unobtanium for now.
A slight chance is the push-on push-off **** has a kaput internal tact switch. That would need careful surgery. Try wobbling that **** switch in before doing the jumper to check if the $0.01 tact switch is bad. If you had rain ingress, that pin 5 circuit inside may be corroded impairing the 'turn on' signal you see as 1.6V
Other related links that show the tact switch and rainproofing after repair ----> https://landroverforums.com/forum/di...inroof-123134/
----> https://landroverforums.com/forum/di...-radio-123928/
EastCoast
Jun 21, 2017 04:03 PM
jeepguywithadisco
Jan 1, 2015 07:53 AM
TOM R
Oct 11, 2014 01:33 PM
cocca
Jan 8, 2008 09:04 AM
bweaver
May 6, 2007 09:47 PM
