Random misfire and power dropping out
Old Feb 15, 2012 | 10:29 PM
GARovee's Avatar
Awesome. Thanks. Going thru them now..
Old Feb 15, 2012 | 11:30 PM
GARovee's Avatar
I cleared the codes... did a fuel pressure test while running. The random misfire and cyl #5 misfire came back while I was running the fuel test. The whole time I had a steady 42-44psi fuel pressure. Fuel pump is okay then I guess?
Old Feb 15, 2012 | 11:43 PM
GARovee's Avatar
Was doing more research... Came across this
"A bad crank position sensor can worsen the way the engine idles, the pistons fire, or the acceleration behavior. If the engine is revved up with a bad or faulty sensor, it may cause misfiring, motor vibration or backfires. Accelerating might be hesitant, and abnormal shaking during engine idle might occur. In the worst case the car may not start."
Sounds almost exactly like what I'm experiencing... any thoughts on testing this?
Old Feb 16, 2012 | 04:37 AM
Crank sensor is one that the ECU has no back up plan for. Erratic ones typically cause stall when hot, and no re-crank until cooled off. But they can make strange things happen, and do fail. Guys carry a spare one when going way off the beaten path.
The unit is a reluctor pickup sort of device, the nose of it is like 2 mm away from the slotted ring you see on the front of the flywheel (not the teeth that the starter engages). Those notches are 6 degrees apart, and there is a gap that indicates position to the ECU. Metal trash on the nose of the sensor could be an issue as well. They're like $70 -90, a PITA to install, plug in and let hang down before mounting. Spacers have to go in as shown, so nose is a precise distance from the internl disc.
And there are pages about that timing in the Bosch manual I sent you. The pages from the RAVE show a voltage chart vs RPM, so that could be monitored, but of course the unit needs to stay plugged in or truck won't run. The norm for yes/no is when truck dies and won't recrank: pour cold water on it, or spray with brake cleaner (cools off).
Attached Thumbnails Random misfire and power dropping out-d1-reluctor-ring-oil-pan.jpg
File Type: pdf
File Type: pdf
File Type: pdf
Old Mar 6, 2012 | 11:12 PM
hhalimi's Avatar
GA Rovee, did you find what the problem was?
Old Mar 23, 2015 | 10:25 PM
mr4x4's Avatar
Cool p0451 and p0300
Hi I have a 1999 Land Rover Discovery SD (1) I'm pulling code p0451 which has something to do with fuel tank pressure and im also getting p0300 which means random misfire. I changed two coils, plugs, cleaned MAF and changed a busted O2 sensor. What should I do?
Old Mar 24, 2015 | 06:20 AM
drowssap's Avatar
you should start your own post piggy backing on a 2-year old post may not get you far.
Old Mar 25, 2015 | 11:08 AM
mr4x4's Avatar
Yes your absolutely right but to be perfectly honest I don't know how to start my own post. Could you teach me?
Old May 26, 2020 | 10:20 AM
Icee Elvis's Avatar
3rd Gear
Default Same problem.
Good day sir. I have same problem with my 06 sport supercharge. I have change spark plugs, coils, o2 sensors, catalytic converter. but still same problem. Pls did u fine out what's was the problem?
Old May 26, 2020 | 10:26 AM
Icee Elvis's Avatar
3rd Gear
Good day sir. I have same problem with my 06 sport supercharge. I have change park plugs, coils, o2 sensors, catalytic converter. but still same problem. Pls did u fine out what's was the problem? I have put more than $3000 but still same problem. random misfire and pawer dropping out.
Edit Quote
oilspotLR
Sep 25, 2022 08:14 AM
disco2003
Jul 20, 2016 04:59 PM
wyattparke
Jan 5, 2013 03:05 PM
pdowning6
May 12, 2012 10:30 AM
nycdisco85
Sep 5, 2011 10:31 AM
