random stalling while stopped has turned into rev limited to 2,500 and limp mode
Hi iv looked all over this forum trying to find a thread like the issues iv been having so I figured it best I describe them and see you guys think.. iv got a 2000 discovery 2 with the v8. a couple months ago she started randomly running rough while stopped at stop lights which then turned into stalling, and has now progressed to the point where at any time I get up 2,500 rpm it hits what id like to call a rev limiter and immediately goes into what I assume is limp mode sport and manual mode flashing on the dash and the the lights on the shifter flash. along with that it also seems stuck in a high gear, I scan still go into reverse and all but wont come out of the higher gear. I have had it plugged into my modis edge and have pulled a few different codes which I will add later. iv recently changed the crank sensor a while back, cleaned it a few days ago and changed plugs and wires(which I some how managed to do with out removing the intake plume). after cleaning the sensor and changing plugs and wires she seemed to run fine for a few days until last night the same symptoms reoccurred... my mind is now drawing a blank as what I think it could be.... please help I love my disco!!
My scan tool is a snap on modis edge. I've tried watching the data steams while some one else drove but as soon as it hit 2500 and started doing it, it kicks the scanner out and I have to back up and go back into.the system and then it shows misfires and low voltage and stuff.. I didn't get a chance to check bc it ha once again gone back to running fine
Rickey_240
04-02-2010 05:33 PM
xb70valkarye
02-02-2010 10:13 PM
flygirl92
04-26-2007 06:54 PM
