Is the Range Rover 4.6 (P38) different than the Disco 4.6?
Old Feb 20, 2013 | 07:42 AM
  #21
jafir's Avatar
Also, the P38 4.6 is going to have a different front cover than the Disco 4.6, but it will probably work, or you can swap a new disco cover onto it.
Old Feb 20, 2013 | 08:58 AM
  #22
Dan7's Avatar
I just pulled the trigger on an 00 P38 RR long block for my 04 DII. It's Bosch (so the CPS mount will be the same) and comes with the correct SAI heads. I spoke with a lot of builders and got a consensus that to truly fix the problems inherrent in the 03-04 models, you need to start with an earlier block, made before the tooling issues. So with that as the base, + top hat liners, I should have a fairly reliable block.
Old Feb 20, 2013 | 09:02 AM
  #23
toad2's Avatar
Good for you, Dan.
If you don't mind me asking, how much and what mileage?
Old Feb 20, 2013 | 09:25 AM
  #24
Dan7's Avatar
It was an 04, SE7, 1 owner, 60K mi, clean CARFAX DII for $12K. Runs great (no overheating) but I think it needs a new head gasket and has a slipped sleeve rattling so I thought this might be a good time to do the engine upgrade.
Old Feb 20, 2013 | 09:42 AM
  #25
toad2's Avatar
I meant the new engine you bought.
Your DII sounds the same as mine.
Old Feb 20, 2013 | 10:08 AM
  #26
Dan7's Avatar
Engine is from Great Plains Rovers...tost for long block was $5,750. Mileage is under 100K on the block with no cracks. You can read their tutorial on their website if you're interested in what they do to it.
Old Feb 20, 2013 | 10:44 AM
  #27
drowssap's Avatar
I think he was asking what you paid for The "I just pulled the trigger on an 00 P38 RR long block for my 04 DII"
Old Feb 20, 2013 | 11:01 AM
  #28
Dan7's Avatar
$5,750...in previous post.
Old Feb 20, 2013 | 11:29 AM
  #29
toad2's Avatar
Thanks for the info. Too steep for me.
Old Feb 20, 2013 | 11:36 AM
  #30
ZGPhoto's Avatar
Too steep for most people unless they completely rebuilt it with ARP studs and top hatted liners.
