Rattling Sound
on
We need more information then that, get under the hood and listen closer.
If it was the chain, and at your mileage, it is getting sloppy. If you feel it is coming from the front cover area, then buy a new chain and gear set along with the oil pump repair kit and go for it before it fails.
It is your SLABS unit, that is the ABS modulator (as well as a few other things) that is making the noise, there is a TSB on it.
After you shut your truck off go back out 10-15 min later and see if you can still hear the noise from under the hood.
If you were to let the truck sit for a week undriven the battery would go dead.
Take it to your dealer and have them check the TSB status of your truck.
