Ready to buy MAF
Old 09-18-2010, 06:41 PM
cwood's Avatar
Default Ready to buy MAF
I am convinced that I need a new mass air meter after doing some research or reading of previous threads, with my codes being lean condition on different banks,transmission code,4th gear ratio code,sluggishness and it seems to only be switching to OD at 55mph around 2500rpm's. I read that I only need to buy a OEM MAF, are the Bosh mass air meter that go for around $125 a OEM part,like the ones on autopartswarehouse.com. I want to be sure that I purchase the correct one.thanks,CW.
Old 09-18-2010, 07:01 PM
lipadj46's Avatar
call will tillery, pt schram, paul grant, BP parts of utah etc. No reason to go to a non rover specialist IMO.
Old 09-19-2010, 03:56 PM
cwood's Avatar
Thanks, I will give one of these guys a call tomorrow.Craig
Old 09-19-2010, 04:15 PM
do you have someone near you that you can swap the MAF with to "test" it out? if you do need an MAF I would buy a new one not a used one. and I would buy it from a reputable LR parts dealer like AB, rovers north etc.. it has to be a Bosch in a LR box
Old 09-19-2010, 05:25 PM
cwood's Avatar
I thought that I was be able to get one off of the one that I got the motor out of but someone beat me to it (it would have been free probably). I was thinking of calling BP of UTAH to order one tomorrow ?I was also looking at the ones at autopartswarehouse but they seem to be a "generic" Bosh MAF. I just want to get the correct one and not have to worry about it,but would like to get the best price.thanks,CW.
Old 09-19-2010, 05:34 PM
NiteTrain's Avatar
have you tried cleaning it with some electrical contact cleaner? that did the trick for mine...I think they don't like dirty air filters.
Old 09-19-2010, 05:56 PM
you cant clean a D2 MAF it will kill it for sure. Dont buy the cheaper MAF from BP that is the wrong one.
Old 09-19-2010, 05:57 PM
cwood's Avatar
I have not tried cleaning it..does that usually work? I am also concerned about the K&N filter that I have after doing some reading. Thanks,CW.
Old 09-19-2010, 06:13 PM
lipadj46's Avatar
Throw away the K&N and get a proper paper filter, the oil in them will kill your MAF, not to mention they let in more dirt which causes more wear in your engine. If your MAF is on the fritz try to clean it very gently, they are easy to kill by cleaning.
Old 09-19-2010, 06:51 PM
agreed get rid of that filter it killed your MAF. go back to paper.
Quick Reply: Ready to buy MAF
