Real time help needed! Vibrations!
Old 03-07-2011, 12:01 PM
fj60disco's Avatar
Default Real time help needed! Vibrations!
I just developed a vibration between 30-45 mph it's not a balance issue on the wheels or u joint. It feels like transfer or close to gearing. Anyone have a clue?
Old 03-07-2011, 12:05 PM
Bundu's Avatar
Banned
First suspect for vibrations at that speed is a failing front drive shaft. I know you say it is not a u joint, but how can you tell for sure? One way is to remove the front drive shaft, lock your CDL and drive it and see if it still vibrates.
Old 03-07-2011, 12:13 PM
fj60disco's Avatar
I did inspect the drive line while the rig was in neutral and foot on brake. There was a bit of play at the flange end going onto the transfer off the flange. But not in the joints itself. The flange has some play.... Is that normal there.?
Old 03-07-2011, 12:23 PM
Bundu's Avatar
Banned
There is some normal play or drive line slop.
The front drive shaft u joints is a known point of failure. Has your drive shaft been rebuilt?
Old 03-07-2011, 12:24 PM
fj60disco's Avatar
Lock my CDL?
Old 03-07-2011, 12:26 PM
fj60disco's Avatar
It's. Never been rebuilt or replaced
Old 03-07-2011, 12:32 PM
Bundu's Avatar
Banned
CDL = central diff lock on the transfer case. You have a 2001 and it could have CDL, not all of them do. You need to feel above the front output shaft for a nipple, this allows you to lock the CDL. If you can lock it then you can pull the front drive shaft and do a test drive to see if the vibrations are gone.
Some useful CDL info here: http://www.landroverclubvi.com/2003cdlinstall.html
Look here for rebuilding the drive shaft: https://landroverforums.com/forum/sh...ad.php?t=29302
Old 03-07-2011, 12:34 PM
fj60disco's Avatar
No locker on mine. Just high and low. My 99 has it!
Old 03-07-2011, 12:35 PM
Bundu's Avatar
Banned
The 2001 did not have a shifter to engage CDL, but it may have a CDL equipped transfer case. The fact that you do not have the shifter does not mean that you do not have CDL.
Old 03-07-2011, 12:40 PM
fj60disco's Avatar
I'm going under it now to check
Quick Reply: Real time help needed! Vibrations!
