Rear ABS Sensor question
Old Feb 15, 2014 | 03:28 PM
LADEROUTE's Avatar
Default Rear ABS Sensor question
Background:2004 Disco.
- Rear diff exploded on trail.
- Swapped out rear axle for used one.
- ABS light came on after swap ( 0605 rear left sensor output too low )
- Mechanic wanted to install a new hub assembly but I knew I had 2 good hubs on my "old" axle - had enough fighting with the mechanic......
- After pulling the left rear hub and swapping for one of my old ones and deleting the code the test drive proved no difference.
- Upon looking on line for a cost effective abs sensor I started seeing pictures of the abs sensors and then it dawned on me......
I did not have the little rubber ring seal on the abs sensor that goes into the hub!!!!! The SOB must have not put it on when he swapped it out!
My question is would the difference of depth from that little seal not being on be the difference in the sensor not working properly therefore sending out a justifiable code of " rear left sensor output too low "
Thank you in advance - Paul
Old Feb 15, 2014 | 09:20 PM
ralphobell's Avatar
I have noticed those connectors can be quite finicky. It is basically just an o-ring to help keep moisture out and it may help lock the connector in place. If the prongs look bent try a pair of pliers on them gently. Also the female connectors can get a little out of shape. So you might want to squeeze them a little as well to try to make everything a tight fit.
Old Feb 16, 2014 | 09:34 AM
LADEROUTE's Avatar
I looked over the connectors and they were pretty clean and straight.
Before we swapped out the rear end there were no lights on at all, I swapped back in one of my old hubs I knew to be fine to the corner making the code and still nothing....leaving the only missing link to be this little rubber seal..... It is such a minimal margin that a little magnetic item may just be set off by a mm or so....
I'll keep you posted
KlamathMatt
Apr 17, 2020 05:27 AM
colemtd
Mar 30, 2019 08:57 PM
LADEROUTE
Mar 12, 2014 08:58 PM
twaszak
Jun 4, 2011 07:49 AM
