Rear AC Not Working
Old Oct 2, 2021 | 12:06 PM
Hensel's Avatar
7th Gear
Default Rear AC Not Working
Hello! I recently purchased a 2003 LR Discovery 2 SE7. The rear AC does not work. The 25 AMP fuse was blown. I replaced the fuse with the vehicle off and the fuse immediately blew. Can anyone help me with next steps? Thanks for your consideration!
Old Oct 2, 2021 | 01:38 PM
Best4x4's Avatar
Sounds like rear blower is inop. AC flows thru the system all the time if the front system is on. Rear switch works then fuse pops? Check rear blower IMHO
Old Oct 2, 2021 | 05:18 PM
Hensel's Avatar
7th Gear
The fuse blows as soon as it is inserted. The key is in the off position. Where is the rear blower located?
Old Oct 2, 2021 | 09:33 PM
mollusc's Avatar
Sounds like you need to get yourself a copy of the RAVE manual. Plenty of download links on this forum if you search. That will tell you that the rear blower is in driver's the side cubby behind the second row of seats. It will also tell you how to open up the cubby and access it, and a whole lot more information that you'll need to diagnose and repair this issue.
1998Disco1
Jul 30, 2013 08:33 AM
boris_gti
Oct 29, 2011 12:39 PM
pedro_malo
Sep 8, 2008 03:51 PM
rirover
Jul 7, 2006 05:56 PM
