Rear bearing separation from hub ?
Old May 12, 2022 | 08:55 AM
Externet's Avatar
Question Rear bearing separation from hub ?
Hi.
Just ordered a replacement bearing and later noticed it is the bearing only without the hub. Before it arrives and work starts, how to separate them when being removed from the vehicle ? I do not need a new hub, so ordered the bearing alone properly; but got the doubt.
----> https://www.ebay.com/itm/18506936619...53.m2749.l2649
Old May 12, 2022 | 10:20 AM
mollusc's Avatar
I made the same mistake recently. Luckily it turned out that I only needed the sensor so I didn't have to mess with separating them. The RAVE makes it seem like the hub is a press fit into the bearing.
Old May 12, 2022 | 06:29 PM
RoverMasterTech's Avatar
It's easy, you return the bearing and order a hub assembly.
flyer08
Dec 21, 2021 09:48 PM
Shelly23
Oct 31, 2021 10:57 AM
Shelly23
Oct 30, 2021 08:51 PM
Dv8er
Apr 27, 2017 03:15 PM
Externet
Aug 26, 2013 06:45 PM
