rear brake pad change
Old Mar 4, 2013 | 08:23 PM
jhill15's Avatar
Originally Posted by 1danger1
Mike what's the best way to do a full system flush. I'm planning on doing my rear pads also. What method do you suggest. Also my BMW 740i has sensors that need to be replaced when the pads wear past a certain level, does my 04 disco SE have these also?
That's a great question left for the masters. Are your amigos present? I would think if the sensor were bad then the amigos would show up.
Mike, Savannah, Spike, Coors, anybody know the answer?
Mine are pretty crunchy when I hit the brakes so I have stopped driving until I can replace them but I would like to know as well. If the sensors will go bad if reached a certain point of pad wear?
Old Mar 4, 2013 | 09:09 PM
No there are no wear sensors.
A brake fluid flush is a brake fluid flush,if you've done it on one car you've done it on any car, drain out all of the old fluid, add new and start bleeding the brakes.
I start at the right front wheel and work my way to the right rear, then left rear, then left front to finish it off.
Others start at the right rear, left rear, right front, left front.
In my opinion it does not matter because it is a 4-channel braking system so each and every brake line has its own supply of fluid.
You will need 2 qts.
Old Mar 4, 2013 | 11:09 PM
aarongregor's Avatar
rear brakes are a breeze Jon, if you have a problem hit me up. When I flushed mine it was as spike said 2 quarts. You may want to when you have it apart pull the abs sensor and clean it. That throws our 3 friends on as well...
Old Mar 5, 2013 | 06:54 AM
jhill15's Avatar
Hopefully I can do it on Friday when it warms up, for now she's sitting until I get it done. Aaron I will prob be calling ya lol I'm think about doing my rotors as well. They have some rust on the outer side wall of them and look pretty bad. Idk how bad they actually are but if I'm gonna be in there I may as well.
Old Mar 5, 2013 | 09:14 PM
Jon I will keep my phone handy lol...Im doing my fronts this week sometime. I bought the Terrafirma rotors and the Akebono ceramic pads. I brake like an *** so I blow through rotors and pads, I hope these hold up better. I did not forget about your nuts lmao!!!
Old Mar 6, 2013 | 06:40 AM
drowssap's Avatar
big thing to check is make sure the guide pins for the calipars move in and out easily
Old Mar 8, 2013 | 03:55 PM
jhill15's Avatar
Everything went great, the rotor on my driver side was trashed and the caliper pins were frozen but a little pb blaster and they can right out. No problem with the passenger side easy cheesy took me 4 hours to do it but well worth it....mission accomplished
Thanks guys
Old Mar 8, 2013 | 05:42 PM
Good to hear Jon!
jastutte
Apr 28, 2013 02:39 PM
Disco Alan
Apr 1, 2012 07:29 AM
caljw
Dec 2, 2011 08:46 AM
collin Barrows
Aug 28, 2011 07:13 AM
batiscan
May 25, 2011 08:10 AM
