Rear cargo door leak
What Best said or if you don’t have a bungee cord some backer rod from Lowes or HD. Also you can adjust the rear door striker inward to close the door a bit tighter.
I’m not sure if this is your issue or not, but mine had too much gap at the upper edge of the door, so it couldn’t seal. I loosened all the hinge bracket bolts and then, with the door wide open, I lifted the left (now back) corner of the door while my wife tightened the bolts. This closed the gap at the seal (actually I got it too tight on my first attempt). It seems to seal fine now.
cvhyatt (03-12-2022)
archaeology_student
08-07-2013 03:23 PM
