Rear cargo door leak
Old Mar 11, 2022 | 01:40 PM
Brandon318's Avatar
Default Rear cargo door leak
Both Discos have a nice puddle of water sitting on the cargo mat after a car wash. Both have ladders. Always been a problem and keep forgetting to ask if anyone has found a good fix.
Old Mar 11, 2022 | 01:43 PM
Best4x4's Avatar
I've cut a large bungee cord & stuffed it behind the gasket across the top and it stopped water from seeping in around the ladder.
Old Mar 11, 2022 | 03:42 PM
zski128's Avatar
What Best said or if you don’t have a bungee cord some backer rod from Lowes or HD. Also you can adjust the rear door striker inward to close the door a bit tighter.
Old Mar 11, 2022 | 04:07 PM
Harvlr's Avatar
I’m not sure if this is your issue or not, but mine had too much gap at the upper edge of the door, so it couldn’t seal. I loosened all the hinge bracket bolts and then, with the door wide open, I lifted the left (now back) corner of the door while my wife tightened the bolts. This closed the gap at the seal (actually I got it too tight on my first attempt). It seems to seal fine now.
nashvegas
Sep 23, 2020 07:47 AM
archaeology_student
Aug 7, 2013 03:23 PM
aarongregor
Mar 24, 2013 10:09 AM
Disco2Guy
Nov 11, 2007 08:37 PM
pinba1173
Sep 15, 2005 04:19 PM
