Rear Cargo Door Won't Open
Old Oct 17, 2007 | 10:55 AM
CPDieker's Avatar
Default Rear Cargo Door Won't Open
I have had this problem before, but I would cycle the locks a couple of times, drive it for 15-20 minutes and that would resolve the problem.
It has been four weeks now, and the back door won't open! I am getting ready to go on a road trip and need that door to open. The handle on the exterior will actuate as will the latch on the interior. The lock cycles- but nothing. I think that the bail is frozen in the lock position, but I can't figure out how to get to it.
Any suggestions? I need you input ASAP. Thanks!
-P
Old Oct 17, 2007 | 11:43 AM
Dahne23's Avatar
Default RE: Rear Cargo Door Won't Open
maybe try to take the Land Rover emblem off on the back and spray it w/ WD40. Worked for me! hope this helps!
D-
Old Oct 17, 2007 | 12:26 PM
That is the fix.
Old Oct 17, 2007 | 01:24 PM
hobiecat's Avatar
I have had problems with the back latch on my truck.
I just spray it with WD-40 and keep working the latch.
You may have to keep moving the handle back and forth until it finally works on its own.
I had to open the back door from the inside to get the door open and then I sprayed WD-40. Be careful as the oil will drip all over.
jimvw57
May 23, 2014 08:59 PM
billinohio
Feb 28, 2007 12:03 AM
adowgiert
Mar 1, 2006 08:05 PM
saltyrover
Feb 20, 2006 04:39 PM
