Rear Diff
Old Jul 16, 2009 | 06:37 PM
blcp86's Avatar
Default Rear Diff
I was changing my diff oils today, and after changing the front i moved onto the rear and when I removed the drain plug it came out looking like liquid metal, and there was a good amount of metal shards stuck to the magnet, but no big chunks came out...
It is an 03 discovery with 64k miles. She was driving just fine before i changed it and she drove home just fine...is this normal?
Oh and thanks for the help with the SES light, it went off this morning.
Old Jul 16, 2009 | 07:33 PM
antichrist's Avatar
No, not normal. You're shredding something in the diff.
Old Jul 17, 2009 | 08:33 AM
Start looking for a good used 3rd. member, you are about to need one.
Old Jul 17, 2009 | 11:47 AM
WhiteD1's Avatar
5th Gear
X2... its usually the spider gears and cross shaft. Traction control is pretty hard on those parts.
Old Jul 17, 2009 | 02:33 PM
blcp86's Avatar
Does anyone happen to know where I can find a replacement...new or used? And is this something that can be done in your garage or should I just take it to a shop?
Old Jul 17, 2009 | 02:59 PM
WhiteD1's Avatar
5th Gear
Great Basin Rovers offers diffs with new gears or re-manufactured diffs. 1-801-486-5049.
Old Jul 17, 2009 | 04:55 PM
Bill, who I really like, will charge you way to much for a replacement.
How mechanical are you, can you replace it your self?
Old Jul 17, 2009 | 05:01 PM
www.roverlandparts.com
www.autosportsunlimited.com
Old Jul 17, 2009 | 05:25 PM
antichrist's Avatar
http://www.roverguy.com/
It's easy to swap out the rear diff. Two sockets, one for the axle drive member bolts, one for the diff carrier to axle housing bolts and two wrenches for the rear propshaft to pinion flange bolts.
Old Jul 17, 2009 | 11:16 PM
roven's Avatar
4th Gear
Question Traction control
Is it possible to just get rid' of this?
