rear door latch/lock
Old Mar 25, 2008 | 12:33 PM
dkeach's Avatar
Default rear door latch/lock
Here's one.............I have a '99 D2 w/ 120,000 miles.
The rear door lock will not unlock with the remote along with the rest of the door locks.
It will lock with the remote but sometimes it does not. it does lock when you start driving, along with all the other doors.
you have to pull the handle on the inside of the door to unlock it.
When you lock the vehicle andarm the alarm system,and the rear door does not lock, the alarm will still activate when you open the unlocked rear door.
Until I get this rectified, I have rigged myself a coat hanger to hook the rear door handle from the back seat.
Anyone ever heard of this problem? I've called AB to check on what Rave calls a "Tail Door latch and motor". The guy couldn't find it but is researching it.
Thanks.....Doug
p.s. if the child proof switch had been thrown, I'd be screwed.
Old Mar 25, 2008 | 01:28 PM
Urban Panzer's Avatar
Default RE: rear door latch/lock
Hi, VERY common problem, sometimes its just a sticky linkage that needs lubing, or the latch mechanism / lock assy can just "wear out"
Try at first to lubricate the door lock assy, this can be done by "popping" of the rear land rover badge where the number platelights are, and then spray some lubricant in there. Sometimes this is enough to fix the issue.
Old Mar 25, 2008 | 02:24 PM
jkid's Avatar
It's most likely very dirty in there. Spraying through the LR logo will only fix the handle (which does stick) but will not help the locking mechanism. Sounds like you need to get the latch out andclean/lube it real good. It's not too hard, check it out:
https://landroverforums.com/m_57657/tm.htm
Old Mar 25, 2008 | 03:03 PM
dkeach's Avatar
ORIGINAL: jkid
Thanks for the responses. The issue at hand is not so much the operation of the latch as it is the ability to unlock the door with the button on the key. I find myself wishing there was an actual place to insert a key and physically unlock the door. I will disassemble and do further TS on it and report back.
dk
Old Mar 25, 2008 | 06:16 PM
jkid's Avatar
Sounds confusing... So none of the doors unlock withthe remote?It sounds like it's not too consistant. Could be the battery is dying in the key FOB or it's broken. Open it up and check it out. You may find some a loose button that needs to be resoldered. Also check the plug at the latch in the door.
Old Mar 26, 2008 | 09:18 AM
dkeach's Avatar
Key battery is about a month old. The remote works fine.
All other locks work normally: When unlocking::ush unlock button once....drivers door unlocks
push button a second time....all other doors unlock except therear(tail) door.
When locking::: push button once and all doors lock including the rear(tail)door.
if lock button is pushed twice fast....all doors lock and hazard lights flash twice indicating the arming of the secondary alarm system.(motion sensor system)
The only way to unlock the tail door is to pull the lever on the inside of the vehicle.
pimnmike
May 23, 2012 09:53 PM
townespm
Jan 28, 2011 09:23 AM
townespm
Jan 24, 2011 08:52 AM
CandiMan
Aug 24, 2008 10:35 PM
