Rear door license plate nut/fastener/rivet? Broke
Old Nov 20, 2007 | 03:07 PM
BradHall's Avatar
Default Rear door license plate nut/fastener/rivet? Broke
The license plate pressed in aluminum nut rivet thing is broke on the discovery I bought. It looks like someone tried to put the wrong size bolt in it and then broke the nut away from the retainers/rivet. I cut the bolt off and the back of the nut just fell out but the press in rivet thing is still there is there any place I can but these again to try and make a factory style again.
Old Nov 20, 2007 | 03:49 PM
dkeach's Avatar
Default RE: Rear door license plate nut/fastener/rivet? Broke
http://www.roverconnection.com/
there are plate mounts on this site
Old Nov 20, 2007 | 07:44 PM
BradHall's Avatar
I looked on this website and all I seen was a license plate frame and a gasket. I'm needing the push in nut/aluminum slug.
Old Nov 20, 2007 | 10:36 PM
Jst4fun's Avatar
My nuts on the plate frame fell out as well. They were stripped and rusted.
I kinda cheated. Had some SS 10mm nuts in my case so made them work.
Heated the license plate frame with a heat gun till the plastic was soft and pushed the new nuts in the place of the old nuts (counter-sunk).
Worked great and they wont rust.
Hope this helps.
Regards,
Nick
Old Nov 21, 2007 | 05:09 PM
BradHall's Avatar
It's not in the plate frame it is in the rear door itself on a 1998. They are pressed in. I've noticed that the factory land rover rear lamp guards come with the same pieces but I don't want to pay 60.00 for a whole kit to just use one of the press in rivet/nuts
sdeleve
Aug 23, 2013 10:18 AM
thehulk
Oct 18, 2008 07:26 PM
drzjoint
Jan 8, 2008 03:29 PM
RDM3
Freelander
Dec 15, 2006 04:56 AM
KWAYZ
Dec 7, 2006 09:09 PM
