Rear door liner removal
Old Feb 13, 2011 | 08:05 PM
DiscoBenjamin's Avatar
Default Rear door liner removal
A was replacing my cracked rear wiper arm today and trying to remove the rear door liner to hook up the washer fluid hose but was 3 for 5 on cracking the pins holding the liner on so I gave upon getting it off. The rave's only instructions for removing the pins it to do it "carefully", is there any trick to getting the liner off in tact so it can be reinstalled?
In the end I took the fluid hose that was already in and threaded it into the new arm assembly so it all worked out, but that door liner is beyond me.
Old Feb 13, 2011 | 11:00 PM
'BamaBoy's Avatar
I broke all but 5 or 6 on mine when I replaced my wiper arm. I think it's something like $2 per clip or some outrageous thing like that. They don't break as easily when it's warmer outside. I just spaced mine out and popped 'em back in. You can't even tell that I'm missing any
Old Feb 13, 2011 | 11:27 PM
sloppyjoe's Avatar
i was careful and still busted 4-5. nothing you can do but replace em. luckily its cheap
Old Feb 14, 2011 | 01:46 AM
bosshogt's Avatar
The rear gate is steel. You can glue on 3/4" diameter 1/8" thick rare earth magnets to the back panel. Or replace all the christmas tree clips with these and the panel will come off and on easily when you need to remove it. I am making a Walnut panel to replace the black one this is my easy method for attaching it. I used a bunch of these to acuratly space out my fog lights on my steel bumper.
10 Neodymium Rare Earth Disc Magnets 3/4x1/8 Inch N42
sdeleve
Aug 23, 2013 10:18 AM
lloyd70mb
Jan 21, 2013 02:10 PM
RWM3
Jan 11, 2010 01:24 PM
pinba1173
Appearance & Camping Set Ups
22
Jul 27, 2009 07:33 AM
