Rear Door Lock Actuator 2000 LR Discovery II
Old Oct 16, 2010 | 04:54 PM
DNCIZ's Avatar
Default Rear Door Lock Actuator 2000 LR Discovery II
I bought a used 2000 Discovery and the rear (back) door lock actuator worked for only a couple of days. I found a used one and have installed and it reacts exactly the same. When trying to use it there is a small sound and I can feel a slight vibration so I think it is getting power. Aside from the obvious that this one is also bad, is there anything else that I should check? All of the other locks work with the remote and the console switch. This one also works manually from the inside.
Thank you in advance for your help.
Old Oct 17, 2010 | 08:16 AM
Sounds like you bought a bad used one. As long as you here it trying, it has full power to the system. Try locking or unlocking it a few times and see if it does in fact start working.
Old Oct 17, 2010 | 10:16 PM
DNCIZ's Avatar
Default Thank you Disco Mike
The place where I bought it is sending a new (used) one tomorrow.
Thanks again
kristofferzen
Sep 10, 2015 02:11 PM
marshman 442
Jan 13, 2008 10:15 AM
