rear door window channel seal?
If there is another issue like the door itself, get poly foam caulk from HD about 1/4 or 1/2 inch and insert inside rubber to lessen the gap between door and rubber weather strip.
Im guessing its just the felt channel around the glass.
Cheers
Just check, the window glass channel that usually goes down. You can use a blunt flat screw driver to raise it back up. If it get stuck under the rail inside, then you have to remove the door panel to get it back up. You can then spread a thin layer of adhesive you prefer to get it fix into place.
Cheers
Cheers
I've had to slide my weather strip back up a couple times.
colemtd
03-25-2022 06:48 PM
carid
04-19-2017 08:46 AM
