rear door window channel seal?
Old Feb 5, 2018 | 06:01 AM
MATT04's Avatar
Default rear door window channel seal?
Ive searched the forums and internet and cant find the part im looking for. i have wind blowing in from my passanger side rear door at the rear of my window that rolls up and down, that channel window guide part. Does anyone know where i can buy one.
Old Feb 5, 2018 | 07:19 PM
LR03NJ's Avatar
Just check, the window glass channel that usually goes down. You can use a blunt flat screw driver to raise it back up. If it get stuck under the rail inside, then you have to remove the door panel to get it back up. You can then spread a thin layer of adhesive you prefer to get it fix into place.
If there is another issue like the door itself, get poly foam caulk from HD about 1/4 or 1/2 inch and insert inside rubber to lessen the gap between door and rubber weather strip.
Im guessing its just the felt channel around the glass.
Cheers
Old Feb 6, 2018 | 10:55 AM
Motorhead1's Avatar
Cheers
I've had to slide my weather strip back up a couple times.
Old Feb 6, 2018 | 11:04 AM
MATT04's Avatar
Thanks, i just went out and checked and it did slide down halfway. so for the last couple months ive had wind blowing in when i could have easily fixed it. and i have read about it sliding down but havent noticed it until i put the window down and checked it out
colemtd
Mar 25, 2022 06:48 PM
yonatan
May 1, 2017 05:10 PM
carid
Apr 19, 2017 08:46 AM
kilkenny
May 15, 2015 06:07 PM
0304Disco
Oct 29, 2013 10:32 AM
