Rear drive shaft blow out
Old May 30, 2008 | 10:04 PM
PITTDISCO's Avatar
Default Rear drive shaft blow out
Rear drive shaft gave up the ghost yesterday. The yoke with the splines shot out of the drive shaft. Will a spline shaft from a 99 fit a 96? The rear ofportion of the shaft is fine.
Also it damaged the four bolts coming out of the transfer case. Shop manual doesn't really tell you how to take it apart to get to these bolts. Can anyone of you guys shed some light on this?
Old May 30, 2008 | 10:14 PM
Default RE: Rear drive shaft blow out
As long as it is a 99 DI it should fit.
Go to www.discoweb.org and click on the tech tab under their banner. There is a tip on how to replace a T-case output seal, it might shed some light for you.
Old May 30, 2008 | 10:21 PM
PITTDISCO's Avatar
Hey Spike, thanks for the reply.
I went over there and looked around. It has one tab listed as t-case, and I believe it's on the front that they are talking about.
Old May 30, 2008 | 10:27 PM
Yeah that is all I founf too, but I believe that the front and the rear are the same. The way the DS connects anyway.
Old May 31, 2008 | 12:26 PM
PITTDISCO's Avatar
DiscoMike, thank you! I appreciate the info on how to get this rig back to the house. Now if I can figure out how to get that drum off, so that I can replace the drive shaft bolts.
Thanks again!
Snafu / Disco Fries
Mar 2, 2011 09:20 AM
Paul Grant
Oct 19, 2010 07:10 PM
willlane
May 11, 2010 05:09 PM
Eak69
Apr 4, 2010 11:52 AM
ogden45
Dec 29, 2008 08:29 AM
