Rear Driveshaft PSA - splines are clocked
Old Dec 23, 2021 | 05:45 AM
Extinct's Avatar
Default Rear Driveshaft PSA - splines are clocked
PSA on rear driveshaft removal - the splines are clocked and if you remove the rear driveshaft from the stub shaft at the e brake the splines ARE clocked and must go back in the exact same position.
Old Dec 23, 2021 | 12:50 PM
frostythor's Avatar
Generally I mark up the prop shaft, brake drum, rear flange , on the rotat flex bolt holes, easy to do with a pin punch just a couple of dots next and on the components or a dab of paint
Old Dec 23, 2021 | 05:40 PM
Brandon318's Avatar
Why would they be clocked?
Old Dec 23, 2021 | 06:36 PM
Extinct's Avatar
Because BMW bought Land Rover duh, they needed to make it needlessly complicated.
Old Dec 23, 2021 | 06:38 PM
Brandon318's Avatar
Sounds about right.
Old Dec 24, 2021 | 10:19 AM
Harvlr's Avatar
Balance?
Old Dec 24, 2021 | 02:07 PM
Extinct's Avatar
Originally Posted by Harvlr
Balance?
Only if your manufacturing is so sloppy the two halves are not balanced.
Old Dec 24, 2021 | 03:33 PM
Alex_M's Avatar
That's usual for all manufacturers. It's also a matter of the joints being lined up with one another so there is no strange resonance. It's not so much sloppiness as it is cost effective manufacturing.
Old Dec 24, 2021 | 09:53 PM
Extinct's Avatar
Maybe, but as a guy who has run design and manufacturing engineering for 33 years I would not let one of my engineers design it to be clocked. It is what it is though, just thought I would let folks know.
Old Dec 25, 2021 | 12:37 PM
sdtimb's Avatar
To expand on the PSA...unless they're aligned, they don't fit back together even if you get impatient and try to finesse them together with a 5lb sledge hammer. Or so I'm told.
