Rear fender liner material?
Old Aug 15, 2024 | 07:13 AM
H Hill's Avatar
Default Rear fender liner material?
Need to repair a rust spot in the right rear door jamb. It will necessitate cutting out the rust area and welding in new steel. Is the outer wheel well an actual fender liner, or is it a spray on finish?
I want to have all materials on hand when I do the project.
Any help or information would be greatly appreciated!
Old Aug 15, 2024 | 08:03 AM
mollusc's Avatar
Following, as I have the same issue in the exact same place.
Old Aug 15, 2024 | 08:28 AM
sqlbullet's Avatar
Dunno....But there is a kiwi youtuber "Croker Vs Rover" that has a whole series that is mostly rust repair on a Disco 1. He is pretty good at explaining what he is using any why, and tries hard to be as OEM as possible in materials, unless there is a very good reason not to. Might be worth a watch if you haven't seen it. He also may reply to a message if you asked. (For all I know he is a member here.)
Old Aug 15, 2024 | 08:46 AM
mollusc's Avatar
As a Kiwi myself, I'd hope he'd respond! Might have to use a few code words to be sure he knows.
Disco Den
Apr 1, 2021 05:02 PM
tylor36
Oct 18, 2013 08:51 PM
Sarge103
Jun 20, 2013 07:10 AM
Landifan
Jan 4, 2011 10:52 AM
rizlagreen
Oct 16, 2010 05:34 AM
