Rear Fuel Smell and Two Shot Start
Old Sep 5, 2019 | 09:12 AM
gte619n's Avatar
Default Rear Fuel Smell and Two Shot Start
Hey fellas, have a weird issue with the Landie recently. I'm getting a pretty strong fuel smell from the rear of the vehicle. Today when I went to start the car, it did not fire on the first crank (~8-10 sec). After I stopped and cranked it a second time, it fired right up and ran as usual. Any idea what this might be? Where should I start checking?
The obvious culprits seem like fuel pump or maybe lines/seals/fittings?
Thanks!
Old Sep 5, 2019 | 11:55 AM
Best4x4's Avatar
Sounds like a fuel leak at the fuel pump. You are loosing pressure so it takes 2 attempts to start (builds fuel pressure up again). I’d lift the carpet, remove the inspection plate, and check fuel lines/fuel pump assembly.
Old Sep 5, 2019 | 11:56 AM
gte619n's Avatar
Yup, my guess as well. Is there a seal that perishes that I can reinstall or is it the entire assembly that usually goes?
Thanks!
Old Sep 5, 2019 | 01:17 PM
Best4x4's Avatar
You’ve got a giant seal on the fuel pump, and seals on the lines. I’ve also seen the pump plastic crack & leak.
Old Sep 5, 2019 | 02:15 PM
gte619n's Avatar
I've ordered a new retaining ring and giant tank seal.
I can't find any info on the seals that fit on the lines. Are they just oetiker clamps or is it something exotic.
Thanks!
shady milkman
Oct 3, 2012 01:31 PM
joefresso
Apr 23, 2011 06:03 PM
LeakyDisco
Sep 20, 2010 09:22 PM
Law Dog
Jul 26, 2010 11:04 AM
Roverfix97
Mar 26, 2010 04:41 AM
