Rear Gate Hinges Sprung - Replace or Repair hinges?
I slid off the trail and had my D2 at a very steep angle this past weekend at the Mid-Atlantic Rally in VA, and I attempted to open the rear gate to get some recovery gear. DUH!, It swung hard open with the weight of the door and the spare tire and then I could not get the gate to shut. It is now high and too far toward the latch side of the rear gate opening to close cleanly.
Once on the trail and back to camp, I loosened the hinge bolts and was able to put downward pressure when closing enough to get it in the first latch position. I had to take off the alignment guide wheel on the gate as it was hitting the latch side as extending out too far towards the latch to fit in the opening cleanly. It stays shut, but will cannot lock or go to the second latch position. I can see where the bottom hinge has been stressed and deformed out of shape. My guess is it is better to replace the hinges than trying to beat them back into the correct shape. Am I correct?
Is the removal of the hinges from the rear gate as simple as removing the gate by the hinges and then drilling out the rivets that appear to attach the hinges to the door and re-riveting new/replacement hinges? Any tips or suggestions will be appreciated.
Any luck?
I opened the back door while on a incline and it wouldn't close! I thought I had closed it (rigged),however it did swing open before I could stop. The back door hinges are not bent out of shape.
I will need to replace.
Did you end up doing this yourself ?
If I can find them,then how?
Any advice will help!
The body shop quoted 1000.
thanks
RyanWF
09-12-2013 09:07 AM
Arcon12
12-31-2007 07:13 PM
